Canoni kuulujutud
daddo
Canoni kuulujutud
Postitus Postitas daddo »
Kuna enne uute kaamerate väljatulekut levivad ikka erinevad kuulujutud, siis olgu nende jaoks üks teema, mis siis vajadusel jälle esile kergitatakse.
Igatahes teema loomiseks on hetkel ajendiks kuulujutud 50D- kohta. Nimelt olla Canoni Hiina leheküljel mõnda aega (22.08) olnud hiinakeelne info 50D kohta. Peale erinevatest tõlkemootoritest läbilaskmist jäi sõelale järgnev:
* 15.1 megapixel CMOS sensor
* DIGIC 4
* 1.6x crop
* Dust Reduction
* Auto Brightness Processing
* 95% viewfinder .97 magnification
* 9 point af (All Cross Type)
* 35 meter area equipped with high-precision sensors
* AF Fine Tuning
* ISO 100-12800
* 6.3 fps (high speed) 3fps (low speed)
* Buffer: 16 RAW - 60 JPG - 10 RAW+JPG
* 920,000 points VGA 3.0-inch LCD monitor
* 100,000 cycle shutter
* Rugged magnesium alloy bodyFull Specifications
Canon 50D Full Specifications
General
Camera Type: Has a built-in flash AF / automatic exposure single-lens reflex digital cameras
Media Type: I or Type II CF card, UDMA compatible
Image Sensor Size: 22.3×14.9 mm
Compatible Lenses: Canon EF-series (including EF-S series lenses) (35 mm converted the focal length of the lens focal length is about 1.6 times)
Lens mount: Canon EF mount
Image Sensor
Type: CMOS Image Sensor
Effective Pixels: Approx.15.1 million pixels
Aspect ratio: 3:2
Dust removal function: Auto, Manual, add the dust data
Recording System
Recording format: Camera File System Design Rule 2.0
(Design rule for Camera File System 2.0) (Design rule for Camera File System 2.0)
Image types: JPEG, RAW (14 place Canon original); RAW + JPEG
Records of pixels: (4752 x 3168) Large: about 15.1 million pixels (4752 x 3168)
Medium: about 8 million pixels (3456 x 2304)
Small: about 3.7 million pixels (2352 x 1568)
RAW: about 15.1 million pixels (4752 x 3168)
sRAW1: about 7.1 million pixels (3267 x 2178)
sRAW2: about 3.8 million pixels (2376 x 1584)
Create / select: Folder Yes
Image Processing
Photo style: Standard, portrait, landscape, neutral, reliable setup, monochrome, User-defined 1-3
White Balance: Auto, the default (Daylight, Shade, Cloudy, Tungsten Lamp, White fluorescent light, flash), user-defined, Color temperature settings (2500-10000 K)
Noise Reduction: Can be applied to long time exposure and high ISO sensitivity shooting
Automatic image brightness correction: Automatic brightness optimization
High-priority tone: Yes
The amount of light surrounding the lens correction: Yes
Viewfinder
Type: Eye-level pentaprism
Rate outlook: Vertical / horizontal direction about 95 percent
Magnification: About 0.95 times (-1 m-1, using 50 mm lens on the infinite distance AF)
Focus: About 22 mm (eyepiece lens from the central -1 m-1)
Built-in diopter adjustment: -3.0 - +1.0 M-1 (dpt)
Focusing Screen: Ef-A equipped with the standard screen, and can replace the screen (2 sold separately)
Mirrors: Express back -
Depth of Field Preview: Yes
AF
Type: TTL auxiliary video coincidence, the phase detection
Automatic focus points: 9 (all cross-)
Metering range: EV -0.5 - 18 (23 ° C/73 ° F, ISO 100)
Focus modes: Single AF, AI Servo AF, Artificial Intelligence AF, manual focus (MF)
AF-assist light: By the built-in flash for a short flash
AF fine-tuning: AF can be fine-tuning
Exposure Control
Metering Mode: 35 Zone TTL full-aperture metering
* Evaluation meter (with the focus of any automatic linkage)
* Partial metering (the viewfinder about 9 percent of the area)
* Spot (viewfinder central area of about 3.8%)
* Central focus of the average metering
Metering range: EV 1-20 (23 ° C/73 ° F, the use of EF50mm f/1.4 USM lens, ISO 100)
Exposure Control: Programmed auto exposure (automatic, portrait, landscape, Macro, Sports, Night Portrait, Flash off, creativity automatic, procedures), shutter priority automatic exposure, aperture priority auto exposure, depth of field priority auto exposure, manual exposure
ISO Sensitivity: (Recommended exposure index)
* Basic shooting zone mode: automatically set between ISO 100-1600
* District creative shooting modes: ISO 100 - 3200 (in 1 / 3 increments), Auto, ISO sensitivity can be extended up to ISO 6400 or ISO 12800
Exposure compensation: Manual and automatic exposure bracketing (with manual exposure compensation can be used in combination) - Can be set numerical: ± 2 Stage 1 / 3 or 1 / 2 units to adjust
Auto exposure lock Auto: evaluation of the use of metering single AF mode - Manual: auto exposure lock button
Shutter
Type: Electronically controlled focal plane shutter
Shutter speed: 1 / 8000 second to 1 / 60 seconds (automatic mode), flash synchronization speed of 1 / 250 second 1 / 8000 to 30 seconds, B Mun (the shutter speed range. With the availability of various shooting modes. )
Flash
Built-in flash: Recoverable, auto-flash
Flash: 13/43 (ISO 100, to m / ft unit) flash coverage: 17 mm camera angle. Recycle time of about three seconds
External flash: X series of flash (camera can set up some flash function)
Flash Metering: E-TTL II automatic flash
Flash Exposure Compensation: ± 2 Stage 1 / 3 or 1 / 2 units to adjust
Flash Exposure lock: Yes
PC terminal: Yes
Driving System
Types: Single-shoot, high-speed shot, low shot funny (10 seconds or two seconds delay)
Continuous speed High-speed: Approx. 6.3 / sec. max
Low: the most about 3 / sec.
Continuous maximum number of (High-Speed Continuous):
* JPEG large / distinctions: about 60 (90)
* RAW: about 16 (16)
* RAW + JPEG large / distinctions: about 10 (10)
* Based on these values to use 2 GB of memory cards, Canon testing standards (ISO 100 photos and standard style).
*Value in brackets apply to the testing standards based on Canon’s Ultra DMA (UDMA) 2GB memory card.
Live View Shooting
Focus: Fast mode (testing phase)
Real-time mode, real-time facial priority mode (contrast detection)
Manual focus (can be enlarged five times / 10 times)
Metering Mode: The use of image sensors to evaluate Spot
Metering range: EV 0 - 20 (23 ° C/73 ° F, the use of EF50mm f/1.4 USM lens, ISO 100)
Mute shooting: Yes
LCD Monitor
Type: TFT color liquid crystal display (there are seven brightness adjustment)
Monitor size and resolution: 3 inches, about 920,000 points (VGA)
Coverage: About 100%
Language: Interface 25 (with English)
Image playback
Image display format: Leaflets, pamphlets + information (image quality records, the shooting information, the histogram), four images index, nine image index, rotating images
Zoom: About 1.5 times - 10 times
View images method: Leaflets images, 10 or 100 images, screen, the date, Folder as a unit Jump
High-warning: Excessive exposure of the regional high-flicker
Direct Print
Compatible printer: PictBridge-compatible printers
Print Image: JPEG and RAW image
Print command: DPOF1.1 compatible version
Custom
25 Custom Functions
Camera user settings In the mode dial position of the C1 and C2 registered
Registration menu: Yes
Interface
Digital Video: For computer communications and direct printing (Hi-Speed USB)
Video output terminal: 3.5 mm mini-jack (optional NTSC / PAL)
HDMI mini OUT: terminal C -
Remote Terminal: And N3-compatible line of the shutter
Docking Systems terminal: WFT-E3 Used to connect wireless file transfer for WFT-E3
Power
Battery: Battery BP-511A (1)
* AC adapter can be packaged using the AC ACK-E2
* Installation of the battery box and handle BG-E2N or BG-E2, you can use on the 5th (AA/LR6) battery
Battery capacity shooting (Based on CIPA testing standards): 50 percent of the normal use of flash photography: 23 ° C/73 ° F at about 640. 0 ° C/32 ° F at about 540. 50% of the use of flash photography of real-time display: 23 ° C/73 ° F at about 170. 0 ° C/32 ° F at about 130.
Size and weight
Size (Width x x high-thick): 145.5×107.8×73.5 mm / 5.7 x4.2×2.9 inches
Weight: About 730 grams / 25.7 ounces (body only)
Operating Environment
Temperature range: 0 ° C-40 ° C/32 ° F-104 ° F
Working humidity range: 85 percent or less
Battery BP-511A
Type: Rechargeable lithium batteries
Rated voltage: 7.4 V DC
Battery capacity: 1390 mA
Size (Width x x high-thick): 38×21x55 mm / 1.5 x0.8×2.2 inches
Weight: About 82 grams / 2.9 ounces
Battery Charger: CB-5L
With battery BP-511A, BP-514, BP-511 or BP-512
The length of the power cord: About 1.8 m / 5.9 ft.
Charging time: About 100 minutes
Input Voltage: 100-240 V AC
Output voltage: 8.4 V DC
Size (Width x x high-thick): 91×67x32.3 mm / 3.6 x2.6×1.3 inches
Weight About 105 grams / 3.7 ounces (not including the power cord)
Teine allikas räägib 50D kohta nii:
According to Canon Japan Internas the EOS 50D comes in spring, 2009, exactly on the 05th April, 2009, worldwide presented for the PMA 09 in Wellington, New Zealand. Canon Japan makes this deliberate, because a narrow connection of Japan by New Zealand exists. 50D will have 12 chips MPix of 450D, she offers ISO values to 3200 really as well as by (known) trick to ISO 6400, 3-inch monitor and is sealed even stronger than 40D. It is placed between 5D MKII and 450D (which is removed shortly after from 500D). There will not be 3000D, by the way, because Canon it for holds not possibly to offer a reasonable new-developed DSLR in the prize segment less than 450D (which will cost till then for about 400 € as a set). However, the 50D will have otherwise an as big resemblance to 40D like it had 30D with 20D. The next real generation jump (signal processor, sensor etc.) comes with 60D, presumably in fall 2010. The two-digit remain, in any case, an APS C cameras. The thought is interesting that Canon develops a "3D", the body of 1D has reminded, indeed, rather of the features (MP, speed) of 5D MkII. This 3D closes that (also in price) gap between 5D MkII (approx. $ 3500,-) and 1d MkIII (approx. $ 4500,-). Then the line-up looks like: 450D (500D), 50D, 5DMkII, 3D, 1DMkIII, 1DsMkIII. Suitably to the 50D (in the set) there comes a successor of the USM IS 17-85, the USM IS 16-105. In addition, Canon works on a megazoom lens (as it were to a successor of the 28-300 L), however, nothing has still trickled through precise. And an USM 1.4/35 should complement the L 1.4/35 USM as a "Mainstream-Prime".
