If you have been moving through the Welcome to Japan Festival Playlist, this week's Ram challenge is one of the easier ways to pick up FH6 Credits without spending ages on a single event. It is built around the 2024 Ram 1500 TRX, and once you know the order of tasks, it moves along pretty fast. A lot of players overthink it. You do not really need to. The truck is strong enough in stock form to handle most of what the game asks for, and that is part of why this weekly event feels so clean compared with some of the more fiddly ones.
Getting Started with the Truck
The first thing to do is jump into the 2024 Ram 1500 TRX. If you already own it, great, you can head straight out. If not, it is worth checking the early Horizon events first, since cars like this sometimes turn up there before you even think about buying one. Once you are behind the wheel, the opening objective clears itself, so there is no extra work there. From that point on, the whole challenge is really about choosing the right places and not wasting time with awkward routes.
For the Danger Sign part, keep it simple. Pick a jump with a long approach and a straight run-up. That matters more than people expect. The Ram is heavy, sure, but it has enough power to build speed if you give it room. You do not need a fancy tune just to get this done, though a bit of suspension or engine work can make the launch feel smoother if you already have the parts. Honestly, most players will get the three-star result just by lining up properly and hitting the ramp without second-guessing it.
How to Handle the Wreckage Skills
This is usually the step that slows people down. The game wants Great Wreckage Skills, and that detail matters. Regular wreckage will not count, and if you go too hard off a drop, you can end up with Ultimate Wreckage instead, which is no help here. That is where a lot of players get stuck for a minute or two. The easiest fix is to look for medium-height cliffs or raised ground where the landing is rough enough to trigger the right skill, but not so big that the game upgrades it to something else. Do that five times, and move on.
If you have done a few Festival Playlist weeks before, this kind of task will feel familiar. The trick is not speed, really. It is control. Give the truck a short burst, drop it off the edge, let the skill register, then reset and repeat. It is a bit repetitive, but it is still faster than trying to force wreckage through traffic and hoping the game gives you what you want. That usually ends up taking longer than it should.
Winning the Cross Country Race
The last objective is the easiest if you stay in the same vehicle. Just enter any Cross Country race in the Ram and finish first. That is the whole thing. The truck is made for this sort of event, so you should feel at home pretty quickly. Cross Country races have rough surfaces, sharp turns, and a lot of messy terrain, but the Ram handles it better than a lot of players expect, especially if you keep your line tidy and avoid smashing into every barrier on the way through.
One thing to watch for is switching cars by mistake. It sounds obvious, but it happens. If you leave the Ram and use something else, the challenge progress for the race step will not carry over. Stick with the truck from start to finish and you will be fine. If you want to make the run a bit easier, choose a race with a route you already know. Familiarity helps more than raw speed in these events, especially when the AI starts bunching up at corners.
Final Thoughts
What makes this weekly challenge worth doing is how little friction it has. You are not grinding for hours. You are not learning some weird event gimmick. You are just taking one capable off-road truck, knocking out a jump, farming a few skill scores, and finishing with a race that suits the vehicle anyway. That means the rewards feel solid for the time invested, which is probably why this one gets done so quickly by most players. If you are building out your garage or trying to keep up with the seasonal reward track, it is an easy win, and if you decide you want to push through the playlist faster, some players even choose to buy Forza Horizon 6 Boosting so they can spend more time driving and less time grinding.
