O: Kaamer algajale
Kitu
O: Kaamer algajale
Postitus Postitas Kitu »
Hind võiks olla maks 4000...Tallinn
KarlKr
Re: O: Kaamer algajale
Postitus Postitas KarlKr »
minul hea filmikas müügis....:)
Kitu
pigem thaks digi =)
onedream
Postitus Postitas onedream »
Olympus E500 pakuks huvi ?
petzp1
Postitus Postitas petzp1 »
Sarnase hinnaga on pakkumisel Olympus E-520 Double Zoom Kit (kere + 2 objektiivi). Kasutatud 1 aasta, tehtud u. 13000 pilti. Väga heas korras, väga head pildid teeb, poehind oli u. 9000.-
https://www.osta.ee/index.php?fuseactio ... d=13701136" onclick="window.open(this.href);return false;
petzp@hot.ee
Kitu
E500 on öeldud, et omal ajal oli parim, kuni tuli EOS 350D.....nii et seda eriti ei sooviks =)
ning tal toodud suht palju miinuseid:
Very small viewfinder view (difficult to see fine detail, difficult to check focus)
Recommended sensitivity ISO 100 - 400, images at ISO 800 usable, ISO 1600 not really
Not instant startup (1.7 sec) even longer in its out-of-the-box configuration
Occasional hard clipped highlights, edge jagged diagonals
No record review delete / cancel
Lack of status LCD can mean shorter battery life (LCD monitor takes more power)
Inconsistent automatic white balance in incandescent light
Playback magnification up to 14x but no more detail beyond 8x
Noise tends have the appearance of color mottle not 'film like' grain
Auto focus provides just three focus points, although AF performance good
No focus distance indicator on kit lens
Flash must be raised for AF assist
Color space selection buried in the setup menu (although can accessed from control panel)
Potential to lose images if CF door is opened during write
Only USB 1.1 (still no USB 2.0 Hi-Speed?)
mida sa siis oma 4000 krooni eest tahad? canoni profikaamerat või?
Kitu
Ma arvan, et kui D3000 saab hetkel uue kätte juba 6500 KIT ( http://www.euronics.ee/tootekaart/31854 ... d/D3000KIT" onclick="window.open(this.href);return false; ) (koos mälukaardi ja kotiga), siis mõni kasutatud peaks olema odavam .... kasvõi vaadates E520 kuulutust osta.ee ....
Kui siit mõnda head pakkumist ei tule, siis lepin ka D3000 pakkumisega, kampaania kestab augusti lõpuni =)
samas ma ei tea ka palju kaameratest :(
onedream
Minu E500 hind igaljuhul 3500.- ainult ! Selle raha eest küll paremat ei saa. Ja Eos 350D on ka ikka suht kehvake. Endal läbisõit ˇ5000 nagu uus !
kitu
Postitus Postitas kitu »
mis lisana kaasas?saada palun info emailile adx701(ät)hot.ee :D
Kitu
Kaamera ostetud :D
Neleh
Postitus Postitas Neleh »
petzp1 kas kaamera veel alles?
nippy
Postitus Postitas nippy »
Kui kedagi huvitab siis pakun Nikon D50 müügiks koos kit objektiiviga Nikkor F3.5-5.6 18-55mm
Sellel lehel rohkem infot kaamera kohta. http://www.dpreview.com/reviews/nikond50/" onclick="window.open(this.href);return false;
Algajale on päris hea õppimiseks.
Kui huvi on ... kirjuta meilile: nippy@hot.ee
sc2
Postitus Postitas sc2 »
Canon EOS400D + 2gb mälukart + 18-55mm = 4000eek ?
Kui on huvi siis kirjuta mulle - s2c@planet.ee
